WiFi software update got stuck
Hi
I've just set up my new 820 and I connected it to Garmin Express to install the latest firmware (8.80). When it rebooted it showed the message 'Updating WiFi software' and it just sat there showing this message (with the percent complete showing 0) for about 20 minutes. Having decided it was stuck, I held down the top left button and chose the option to power off. When I switched it back on it went straight into the firmware update process which worked fine (no sign of the wifi software update message). So, a couple of questions:
  • Has the wifi software been updated properly? The 820 shows that it has 'WLAN software' version 2.40. Is this the correct version?
  • Will I have caused any problems powering it off while the update message was displayed? If so, what do I need to do?
  • Should I have done something different when the update appeared to be stuck?
Thanks for any help.
David
    What a mess. Stuck on 6 for about 30 minutes. Powered device off and on Wifi Update popup again, no stuck on 15. When will this be corrected ?? !!
