multiple bikes and one unit
how can i keep track on the miles/activities on one 820 unit and multiple bikes?
    Define 1 profile per bike, and select it depending on the bike you ride.
    how to do it? i have "Activity Setting" i dont see "Activity Profile" on my 820
    It is under Settings / Activity Profiles. Just create a profile for each bike and select that profile before your rides. The 820 saves the totals for each profile.
    I have been searching for this when I replaced the 510 with this 820. The 510 had Bike profiles and Activity profiles.
  • You can also assign different bikes set in the "Gears" section from Garmin Connect (be it mobile or browser based). That's what I actually do. I have a bike (and the components for which I want to track usage) set as the default for Cycling activities and when I use a different bike I manually update the activity. I don't think you can assign different sets of "gears" to different Activity Profiles, but I might be wrong,.
    I have made 2 Activity Profiles for the 2 bikes that I have used so for on my new 820.
    And under History / Totals I can see what I have done with both bikes and the total on the device.ciq.forums.garmin.com/.../1248192.jpg
