Am I correct there is no way to calibrate the Garmin magnetless speed sensor on the 820? The sensor pairs OK, and gives a reading to the 820 which appears accurate. Under settings / sensors, if I select the connected sensor there are no options for wheel circumference etc. If there is no option to calibrate, what method does it use to calculate a linear speed (how far it has traveled in what time period), which from looking at the .fit file is in m/s?
Just an "I'm interested in how this works" question.
