I have an Edge 800, that I bought over four years ago and a recently purchased Edge 820. Surely one would assume as companies and their products evolve new products should get better, not worse!?
So if I turn off all the ancillary stuff on my Edge 820 (i.e. bluetooth, wifi, strava segments, live track etc) then surely the Edge 820 should not have any additional background processing routines compared to the Edge 800? So why is the Edge 820 not able to keep up with grade/elevation, navigation and touchscreen routines in similar fashion to the Edge 800 or 1000? It's time Garmin admitted the fault is either hardware, software or both.
- If hardware (is it processor or other component issue?) then Garmin need to suck it up and either refund/replace our units.
- If software then write some decent code, how about simply copy the base code/routines from the Edge 800, 520 and 1000 units.
I bought the Edge 820 for extended battery life (over my ageing Edge 800) whilst still having maps/navigation out on the open road. The continued silence from Garmin is getting rather ridiculous.
