I've found that default Garmin Open Cycle maps to be a bit difficult to read for mountain biking in some areas so I've downloaded Openstreet maps from http://garmin.openstreetmap.nl/ and have also downloaded a few different style maps from OpenMTBmaps. I've saved all of these maps as gmapsupp.img and tried each of them individually on the 820.
The maps all have their strengths and weaknesses. (for example - the routable openstreet maps are easier to read then default maps when located inside a designated forest area. While the OpenMTB maps allow for easier to see MTB trails but sometimes don't display objects seen in the other maps.)
So my question is - are you able to save multiple files named gmapsupp.img to the Garmin folder so you can more easily switch back and forth between the maps? Or can you name the maps something else and have it still be available on the edge 820?
