Edge 820 and ANT+ magnetless speed sensor not working
Hi,
I set up my 820 switching from a 810 this weekend and at first had trouble finding the speed sensor, which I am not using together with the cadence sensor for I use a Vector2 for that. After manually putting in the Sensor ID, the sensor was found and apparently working. When I took the bike for a ride, I noticed that the speed did not exceed 7,4 km/h and therefore my autostop kicked in ... I could not get it going with deleting and re-adding the sensor, so I just deleted it and the 820 switched to GPS speed which is a pain in the *** if you are riding in the woods ... well, back at home, I did not get the speed over 1 km/h anymore, so I checked the speed with my 810 and it just works fine there. Anyone has the same problem or even better a clue on how to fix this problem ?
Thanks
    I've been using the magnetless speed sensor and Vector 2's (also Edge Remote and Varia radar) with my 820 from day one without problem.
    Try putting it on the rear hub the other way around.
    So u can read garmin from the rear of the bike.
    Worked for me.
    Good luck
