Edge 520 stuck on startup
My Edge 520 is "stuck" on the startup Garmin Logo.  Trying a reset by holding the power button on for 10 seconds only causes the screen to go blank briefly before returning to the startup screen.  In other words the recommended reset method doesn't actually change the circumstances.  Is there anything I can do or is my 520 toast?
  • That is not actually a reset, but rather a forced power down.
    Prompted non-vol clear
    1. Turn device off
    2. Hold the Down key while powering on the device
    3. Continue holding the down key until the “Factory Reset” prompt appears
    4. Select OK to clear
    Non-prompted Non-Vol Clear - Clears NV and deletes all FIT files including Activities, Courses, Workouts.
    1. Turn device off
    2. Hold Lap/Reset and Start/Stop
    3. Press and release the power button
    4. Continue to hold only Lap/Reset and Start/Stop
    5. Release Lap/Reset and Start/Stop when the Garmin Logo is cleared
    6. The unit will restart and clear non-vol
