Hi everybody,
I recently purchased a Garmin Edge 520 with a cracked screen. My idea was to replace it witth the screen of my old Edge 520, which hasn't worked properly since a rainy ride last year. The screen seemed to be fine, however.
When I changed the screen, at first it turned on normally. Luckily I didn't glue anything in yet, because after turning on and off once, the screen was blank, just the backlight working. I thought maybe the ribbon had slipped out, so I put it in again and made sure nothing moved, but encountered the same problem.
So I thought maybe the screen has seen some water after all, and decided to buy a replacement from overseas. Unfortunately, that doesn't work either, just the backlights coming on.
Does anybody have an idea for a fix? Are there screen incompatibility issues within the edge 520 model?
Thanks in advance.
Images:
1. working shattered screen
2 only backlight working on new screen (same occurs in screen from water damaged device)
3. l: shattered screen, m: water damage screen, r: screen from China
