Gaps in GPS/Power/HR Data throughout the end of my ride (Edge 510)
Hi all, I'm not sure I can repair the fit file as I think there were problems with my garmin but im not sure what they were.
I was wondering if my edge 510 here needs to be retired and I should just upgrade to the 530 or 530 plus when that comes out.
I'm not sure if its a battery issue... bluetooth .. software.. There is lots of storage left on the unit, i just wiped it last summer. I did notice about 27km into my ride my phone kept connecting and disconnecting to the garmin.. and thats around the same time you can start to see gaps in the data.. but they show up all through the ride home
https://drive.google.com/file/d/1CnYgtVji4sP6pHNLEBBaCvpSJwU7WgI2/view?usp=sharing
Thoughts? anyone have better tools to see more into the fit files?
Connected hardware
  • Garmin HR Monitor
  • Garmin Vector 2
  • Pixel 2 Phone
  • First, I would un-pair the phone from the 510 and then re-pair them and see if that works.  If that doesn't work try deleting the Garmin app from your phone and reset your 510.  If that doesn't clear things up you may need to revert to an earlier version of Garmin Connect on your phone.  I was having a problem with Live Track not working and the solution was reverting back to Version 4.29.  If you need info on how to revert back to an earlier version you can search the forum and it will come up.  Just be sure that you don't have your apps automatically update or the Garmin will just update itself and you'll be where you started.
