Has anyone seen this before?
I can't get passed it or reset the device. Any ideas?
That is entering test mode. Check that the start button is not stuck down.
Thanks - it looks like it is stuck or at least not returning. Any ideas how to unstick it?
You could try gently working a small screw driver around the sides of the button. Maybe apply a little water if the button is stuck due to use sports drinks. Try pressing on one end then the other end of the button if one end of the button is stuck under the casing.
