Factors affecting battery life
I did a clean reset of my old 520 yesterday and afterwards i ran it sitting on my desk with GPS on and auto-pause off. After 7.5 hrs, it was down the 47% remaining which i thought was quite good (7% per hour and theoretical 14hrs life)
Today i did a ride of 3'32" moving time and 4"36" elapsed time (Coffee!). It was down to 58% remaining which makes it around 9% per hour drain on elapsed time, or around 11hrs theoretical life
The only difference was it was connected to my HR belt and Power Meter and the screen had less fields on it
Either way, the battery life was better than i expected
Brightness was 0%, backlight timeout was 15s, and data recording 1s, bluetooth off, all unused sensors disabled, GPS & Glosnass on, only one data screen was enabled
The questions are
Do enabled data screens that are not being viewed drain battery? Given the data is instantly available when you switch to them (i.e. mapping), i wonder if they are draining the battery in the background
Do calculated fields (like Power 10s, 30s etc....) drain battery more than raw data fields like cadence, heart rate etc...?
Anything else i can do to eek out more life from the battery other than changing data recording to averaging or using GPS only (neither of which i want to do)
Thanks
  • Hi,
    Trying to work out what features increase power usage isn’t easy because we can’t measure current drawn from the internal battery. A while ago I experimented by measuring the current drawn from an external battery (with the internal one fully charged) to see what settings increased power use. I found that from a base case of GPS only, adding Bluetooth (paired with an iPhone but no running apps), Glonass and backlight settings up to about 20-30% didn’t make a lot of difference. High backlight settings had a very significant effect with 100% nearly doubling power use. (Rate of increase with increasing backlight isn’t linear)
    I don't use a power meter or other sensors so i can't help with those.
    The only way to be reasonably certain of what settings cause increased power use would be to do something similar with your own configuration.
  • Wow! 58% remaining? I did a similar length ride with a coffee stop and I had 8% remaining. Even had Bluetooth and GLONASS switched off (which I never had to before). My device is basically now useless on v12.9. Draining 20% per hour.
  • Thanks PeterK_55
    I used 57% yesterday over 5'45" elapsed time yesterday which is about 10% an hour. The performance is slowly worsening CaffeinePowered
    Still not enough juice to get around an upcoming 9-10 hr ride with confidence, so i think i might get a 520 Plus as there are no posts in the forum about poor battery performance, and i don't really want/need something as large as the 1030
  • Mine seems to have serious calibration issues. Finished a 3'45" ride yesterday with 38% remaining - switched on this morning at 36%. 20 minutes later it was showing 43%...
    Gradually went UP!:
    25 mins - 44%
    30 mins - 45%
    35 mins - 46%
    47 mins - 47%
    57 mins - 47%
    1'30" - 47%
    1:37 - 46%
    Then down at the normal rate.
    Still at 38% 3 hours later.
    And Garmin still say that there isn't an issue.
    UK support aren't even responding anymore.
    Is there a way to re-calibrate the battery on a 520?
    Drain to zero and hope for the best?
    Anyone know the EXACT Garmin recommended charging voltage/ampage so I can do this by the book?
    Mains via phone charger or USB via PC etc.?
