Hi,
I am following a Garmin Connect Mobile Workout on my Edge 520 Plus paired With a Kickr Snap smart trainer. I use the built in Indoor activity profile and I have checked and it has the setting for GPS -> Off. But when the activity is completed and upload to Garmin Connect Mobile (and sync'ed to Strava from Garmin Connect), it has a GPS track basically showing a spot with some wobbles around it, centered at my home location. The Activity Type is marked correct as "Indoor Cycling" in GCM but in Strava I have to go edit the activity and add teh "Indoor Cycling" tag to get the map to to be removed. There appears to be no edit option in Garmin Connect itself to turn off the map. Is this a known bug? Why am I getting a GPS track in an Indoor profile with GPS off. It is not clear to me whether the track is being recorded by the Edge 520 plus or maybe added by Garmin Connect Mobile (on iOS) after uploading. In either case it is obviously not valid.
I would appreciate it if someone else who has experienced this could share this experience, or if I could get feedback from people who have this working correctly.
Thanks.
