3.00 Firmware Discussion
Firstly, thank you Garmin for all the new features and bug fixes in 3.00.
Unfortunately Physio-True Up still only works if you have a VO2Max on your Edge.
Scenario - Went for a ride using Edge 520+, it records a Recovery Time. Recovery time does NOT sync to 935.
BUT if you have a power meter or a VO2Max value on the Edge then it WILL sync.
I did raise this with the beta team as part of 2.84 but doesn't look like the fix made it into 3.00
So far that is the only issue I have found with 3.00
    Physio-True Up does not work on Forerunner 645.
    Edge 520+ recorded 19 hours recovery time. Recovery time does not sync to 645.
    I don't have a power meter.
  • Same here, Physio_True Up doesn't work for Forerunner 935.
    Edge 520Plus recorded 21 hours of recovery time, Forerunner displays 0 hours :(
    Both Edge 520Plus and Forerunner 935 display my Cycling VO2Max
    No Power meter
    No Power meter
    How does your edge display the cycling VO2max if you don't have power meter?
  • How does your edge display the cycling VO2max if you don't have power meter?
    I have no idea :( Before strating to use EDGE 520Plus I used to use 935 to record my cycling activities. When that was the case watch did not display Cycling VO2Max, after I start to use EDGE 520Plus, bpth 935 and 520Plus start to display VO2 Max.
  • Recovery Time now syncs back to 935!!
    Talking to the beta team they advised there was a GC Server side update to resolve this issue.
    Note, that the Edge used to (beta anyway) sync at start up so it's Recovery time is updated from the 935 automatically. This no longer happens automatically due to some performance issues. So sync manually at start-up and good to go!
  • Mine syncs as well.
    Forerunner 935 ver 10.10
    Edge 520Plus ver 3.00
    HRM Tri Band
    Recovery time and Cycling VO2Max displaying on both devices.
