I have R8050 Di2 with the WU111 sensor. Everything updated, correctly setup on eTube with the right gear ratio (53/39, 11-28). I have checked this both via bluetooth on iOS and cable on Windows.
However on the 520, the gear ratio shows wrong for the rear casette, but the position is correct using the graphic. Front is fine. Searching around here and it looks like this was an old bug. Has this re-surfaced as a bug?
