Auto Pause is not working properly
I have setup the Auto Pause on my Garmin Edge 520, but I am facing an issue as it pause to record my rides even when I am still moving. I've noticed it pauses when I stop pedaling (on a descent), so I´d assume it´s because it uses the cadence sensor to admit that I´ve stop and not the GPS.
I have set it to use my velocite to pause recording, but it didn´t work as when I am stop pedaling (on a descent) the
speedometer shows 0 km/h. Do someone could help me?
    Do you have a wheel speed sensor? If so, what kind?
    Yes I do. It's the the sensor that came with Edge 520 Bundle (sorry but can't find the model name)
    It is most likely a problem with the wheel sensor. If it is the GSC 10 (that's the cadence/speed combo with magnets) check the alignment of the wheel magnet. It should be centered on the line on the speed arm and the gap should be 2 to 5 mm. If you have the newer magnetless sensor that goes on the hub, I am not sure what the problem would be. You could disable the sensor in settings until you get the sensor problem sorted.
  • You need to change the battery in your sensor. If a hub sensor, you could also move it to the front hub to put it closer to the 520.
    As I can´t find the sensor name I found a pict of it:
    https://www.dcrainmaker.com/images/2014/05/IMG_2970.jpg
    It is new, yesterday I realinged it on the hub, let´s see if it will works properly now if not I will change the battery.
    I´ve also noticed that is not taking the distance correctly so yesterday I changed the wheels size in my device, hopefully it will now be right as well.
