Heart rate zones... LTHR setup in Garmin connect not syncing
Heart rate zones... LTHR setup in Garmin connect not syncing.
I setup hr zones with my LTHR in Garmin connect then connect my ge520 to sync but the hrzones never synced and can't manually do so with LTHR.
Rvert back to manually entering each hr zones (bpm).
Is this an oversight on garmin or me not syncing correctly.
  • it has to be set in the device then user settings on GC, which the site now prompts and it appears to be the only place on Mobile. I've never had an issue with them working, so perhaps take a look again.
    no issue manual entering
    % LTHR is not even an option on the Garmin EDGE 520
    GE520 only has BPM / %max / %HRR
    after you sync (if you setup %LT in garmin connect) - it will show all Zeros in GE520
    If you select %HRR and go back to look then it will setup to your settings resting-max
    and if you go back to set it for BPM then it will select the %LT correctly - there some errors in there but it worked out for me just not intuitive and for sure something is wrong in the sync
