The "OnRoad" format from BBBIKE is highly recommended, I have been using this for 6 months and the file size is much smaller ( or you can have a map of a much larger area) . If you are riding mostly on roads then you don't miss any detail, the things that are excluded appear to be ground cover type shading, points of interest ( eg coffee shops) and street names which makes the map much clearer, less cluttered and easier to view anyway. The map file size for my area is about 25% of the equivalent normal, eg cycle, format
After MANY attempts, I found this page, which finally helped. I used http://extract.bbbike.org/extract.html with the "OnRoad" - Latin1 format (they no longer refer to it as ASCII for some reason) and it's working for me.
Just so that if in case some one stumbles over to this discussion, https://wiki.openstreetmap.org/wiki/OSM_Map_On_Garmin/Download has links to some of the latest and updated places to download the maps from. Like in my case, the maps for India was as recently updated as 13 Mar 22 in one of the website. However, for the Edge 520 Plus, the file has to be renamed to "gmapsupp.img".
In case some one finds that there are missing features like road or POI etc, it is request to please update the same on the cycle map in OpenStreetMap. It'll help us all cyclists as a global community.
Happy Pedalling.
