EDGE 520 dont show map
Hello,
I have a problem, so after the completion of biking and saving the training I'm doing synchro with Garmin Connect (on the phone) and unfortunately in the application can not see traveled route map. Previously, it was ok. I synchro with strava and also there can not see the map.
What's worse I also Forerunner 235 and the last race training is exactly the same. You can see all parameters with the exception of the map. In both cases, it is simply a white box instead of the map.
Both devices have the latest soft.
Maybe someone something he had already such a case.
