Hi there. This sounds EXACTLY the same as my issue. After contacting Garmin, I was sent the following, which I followed exactly and it has fixed the issue. I hope it helps:
Firstly, I would advise to make…
Just a few days ago i had the same thing happen. Edge 520 worked fine one day, next day the bluetooth just wouldnt connect.
The 520 shows the phone as paired, but disconnected.
i have done a reset on the…
Tried many ways but just doesn’t work. I guess the stock firmware is too old to connect to latest iOS. And finally, I’ve done the firmware update from my PC via Garmin Express software and it finally connects to my iPhone 11 Pro. I guess that’s the only way to update the unit firmware (via physical cable) . I’ve not tried to upload any rides yet but will explore more.
Hi All, I had the exact problem and also tried very thing below. Here's how I fixed.
1. Remove the Garmin App
2. Forget the device from you phone and Garmin Device.
3. Download a new version of the Garmin App.
4. Turn on pairing mode from inside the device.
5. Then pair the device from inside the Garmin App (not from phone). Do not use pairing from turning on your blue tooth on phone
5. You have to set everything up again but it works. Note it does not work if you device and phone are paired any other way.
Thanks just back out in the real world today and had the same issue, thanks this solution worked for me
Nice! This worked for me too, so thanks for sharing
I have a 520 Plus running firmware 7.0 and use a OnePlus 6T running Android 10. I find that if I turn off Bluetooth and location on my phone and only turn Bluetooth back on, the Garmin does not connect to my phone. However if I turn location and Bluetooth on, then the Garmin connects. This might be worth a try as I've tried the suggested answer by AdamGee but it kept failing and I had to re-pair both devices after I turned off Bluetooth on my phone and turned it back on.
pls tell me how it is possible that this thread is over 1 year old and this is still a problem. Garmin IS the worst tech company with the worst tech support. I will sell my edge and buy a wahoo...I've had enough of this.. Like why should I do all this stuff just to CONNECT my head unit to my phone...there is no reason this shouldn't work the simple way
