I've recently bought a Stages 6800 Gen 2 unit and my 520 will only reliably display and record power data if it is mounted on the stem. If it is mounted out front I experience constant drop out of cadence and power data.
Using the .fit file repair tool I have noted that signal reception from the Stages is usually 37% with it mounted out front. It is 97% when mounted on the stem. How is this possible? Is Garmin aware of this issue? Do they plan to fix it? I do not really consider having my 520 stem mounted to be a long term solution to receiving accurate power data.
I have tried both the old and new style Garmin out front mounts with no change in reception values (I had thought the extra height offered by the new style mount may have improved line of site).
Has anyone else experienced this issue and are they aware of any work around?
