Is the 520 Cable Propietary?
I lost my 520 USB cable and tried using a different Micro USB cable. I can charge the device, but not see it mounted on my Mac. I have tried a couple of cables and no dice. I dont see an option of buying a cable from Garmin.
Thanks
  • I've never even taken my Garmin supplied USB cable out of the box and just use one that I have lying around from and old Android phone because it's longer.
    I don't know why you are having issues but just about any USB cable should work fine..
  • Many USB cables are for charging only. The cable for connecting the GE520 needs to be a data cable. Either you need to buy it that way, or keep trying cables till one works, then you know it's data capable.
