Not sure if already discussed:
So, today I went to a ride and I had starred I think 5 Strava segments. Only 2 of them worked from start to finish, the rest of them gave Off course during the segment and the segment screen closed without any possibility to bring it back.
This was very annoying as I didn't had the possibility to check my segment time or to know where the segment ends. Big fail on 2 segments believing that they end up but wasn't true.
I have GPS + Glonass enabled but somehow for a short period probably the 520 lost the GPS signal or got some info and decided that I'm off course (which wasn't true at all) and close the Segment screen.
Another friend with Garmin 810 happened the same thing exactly at the same time with me, but on 810 map implementation it seems that the map shows you the segment and the end of the segment with a red square and at least you know if your segment ended or not. But on 520 I didn't saw such thing in navigation screen.
So..any experiences , tricks, solutions for this problem ?
