Setting the wheel size manually in the sensor menu?
Hi,
is it possible to set the wheel size manually in the sensor option menu? With the Edge 1000 you could go to the sensor menu, select the paired speed sensor, select wheel size setting either automatically (GPS + distance) or manually by entering the wheel size in mm.
regards
Chrischi
