Does an existing Strava route exported as GPX or TCX provide turn by turn prompts if I import it to Garmin Connect and then send to my Edge 130? Thanks!
Thanks for the quick reply. My 130's still on order, so I can't test it yet, but thought I'd ask as I get lost easily!
Do you know if a TCX export would be more likely to work as an export from Strava than GPX? As I've read that a TCX has more data?
If you have courses in Strava then you don't need to go through this process.
There is an integration that will push your stared/favorite courses from Strava to GC and they will automatically be down load to your Edge when you sync.
support.strava.com/.../115000919304--Syncing-Strava-Routes-to-your-Garmin-Device
Even better! Thanks for your help. I'll test it out and update this thread once I can confirm it works
Now I've been able to test my new Edge 130, I've had the best results with a TCX export from Strava to give me turn by turn prompts.
A GPX export doesn't give me that info, just a final destination.
Unfortunately, my phone is too old for Garmin Connect! so I'm using Garmin Express to sync. When I upgrade my phone, I'll be able to integrate with Strava more easily.
