Firmware 3.x / 4.0 feature requests here
I'm really happy with firmware 3.0 - almost perfect for me. But I hope it won't be the last update. Since I could't find a main topic collecting all requests for future updates: here you go - please reply with more requests/bugs.
FEATURE REQUESTS
  • adjust auto pause speed (topic here)
  • remove the scrollbar (topic here)
  • add whatsapp / messenger notifications (topic here)
  • quick reply messages by pressing single button with predefined message like "I'm ok"
  • add temperature data field (topic here)
  • change auto lap duration (topic here)
  • add etap / di2 (topic here)
  • Battery level in continuous percentage again
  • Backlight Off setting, that would then allow a press of the power button to toggle the backlight on and off
  • auto power on when sensors get active
  • auto start recording the ride when the sensors report movement / "movement detected" warning
  • total ascent in feet if set to "statute"
  • L/R Power Balance / AVG would be nice for Vectors
  • Naming sensors
  • Vertical Speed (like VS30 in Edge 500) - it's just a calculation of data that already exist
  • Manual Calibration of the Altitude before Ride (topic here)
  • option to delete all logs at once (topic here)
  • improve the UI speed (e.g. pressing stop to having the menu appear seems very sluggish)
  • option to turn off messages like "Press and Hold Top Button to Access Menu", "Backlight Timeout is set to on ....." and "Wait while GPS while cycling outdoor"
  • Larger numbers/characters in fields that cover half the screen. Lots of dead space here: https://media.dcrainmaker.com/images...4/DSC_3616.jpg
  • Disable/Remove Weather and Notifications (Topic)
  • Map: allow user to toggle between north up and direction of travel up.
BUGS
  • Zoom Map In/Out - value can not be changed permanently (Bug? Topic here)
  • Full german translation (new GERMAN.LN3-File)
  • wrong elevation? (topic here and here)
  • BLE speed/cadence paired but not working (Topic)
