Edge 1030 Firmware Version 7.00 now available
Firmware version 7.00 for the Edge 1030 and Bontrager Edge 1030 is now available. This update can be downloaded through Garmin Express or Garmin Connect Mobile when available.
Changes made from version 6.30 to 7.00:
New Feature: Galileo satellites. There is now support to use the Galileo network of satellites to assist in getting GPS fixes. With the correct GPS firmware, this option can be enabled by selecting GPS+Galileo in the GPS setting. Sync the device with Garmin Express to make sure that the new line of GPS firmware is provided to the device. Without this, the option will not be available.
Added cycling dynamics support for 3rd party power sensors.
Updated smart notification categories. In the phone settings, social and other smart notification categories can be enabled. This will make the Edge show notifications from other applications depending on how they are categorized by Garmin Connect Mobile. Apps like WhatsApp, GroupMe, and Twitter may show up under social and things like e-mail, calendar, and news may show up under other. These categories are off by default and must be enabled to be seen.
Fixed an issue causing cadence and power data dropouts.
Fixed the activity profile routing mode getting reset to Road Cycling mode.
Added prompt to indicate when a course has more course points than are supported by the device.
Improved Shimano STEPS response time.
Fixed lens mode VIRB setting.
Fixed issue with transmitting front and rear gear information to the Varia Vision.
Fixed sharp bend notifications on the Varia Vision.
Fixed crash when using Varia Vision with workouts.
Fixed issue with elevation back correction that could allow large dips in elevation.
Fixed issue where the GPS data field did not match the GPS indicated by the status bar.
Fixed issue where virtual partner features were disabled for third party GPX TRK courses.
Added the current software version to the power on page.
Fixed issues with device transfers.
Completing a segment will now turn on the backlight.
Added a minimum scale to the altimeter page so that small elevation ranges are reflected properly.
Fixed elevation zooming issue with large courses/activities/segments (>100mi or km).
Improved activity auto-start when the device is stationary.
Updated radar tone to be easier to hear.
Minor bug fixes and stability improvements.
Bei mir wird das Update in Gamin Express noch nicht angezeigt, sollte aber bald kommen.
    verfügbar
    Die Firmware-Version 7.00 für den Edge 1030 und den Bontrager Edge 1030 ist jetzt verfügbar. Dieses Update kann, sofern verfügbar, über Garmin Express oder Garmin Connect Mobile heruntergeladen werden.
    Änderungen von Version 6.30 bis 7.00 Uhr:
    Neues Feature: Galileo-Satelliten. Es gibt jetzt Unterstützung für die Verwendung des Galileo-Satellitennetzes, um GPS-Fixes zu erhalten. Mit der richtigen GPS-Firmware kann diese Option aktiviert werden, indem GPS + Galileo in der GPS-Einstellung ausgewählt wird. Synchronisieren Sie das Gerät mit Garmin Express, um sicherzustellen, dass die neue Zeile der GPS-Firmware für das Gerät bereitgestellt wird. Ohne diese Option ist die Option nicht verfügbar.
    Unterstützung für die Fahrdynamik für Leistungssensoren von Drittanbietern wurde hinzugefügt.
    Intelligente Benachrichtigungskategorien aktualisiert. In den Telefoneinstellungen können soziale und andere intelligente Benachrichtigungskategorien aktiviert werden. Dadurch zeigt der Edge Benachrichtigungen von anderen Anwendungen an, je nachdem, wie sie von Garmin Connect Mobile kategorisiert werden. Apps wie WhatsApp, GroupMe und Twitter werden möglicherweise unter Social angezeigt und Dinge wie E-Mail, Kalender und Nachrichten werden unter anderen angezeigt. Diese Kategorien sind standardmäßig deaktiviert und müssen aktiviert sein, damit sie angezeigt werden können.
    Ein Problem wurde behoben, durch das Kadenz- und Energiedatenausfälle verursacht wurden.
    Problem behoben, bei dem der Routingmodus für Aktivitätsprofile auf den Straßenradmodus zurückgesetzt wurde
    Eingabeaufforderung hinzugefügt, um anzuzeigen, wenn ein Kurs mehr Kurspunkte enthält, als vom Gerät unterstützt werden.
    Verbesserte Reaktionszeit von Shimano STEPS.
    VIRB-Einstellung für festen Objektivmodus.
    Problem beim Übertragen von Vorwärts- und Hinterradinformationen an den Varia Vision behoben.
    Problem mit scharfen Biegungen beim Varia Vision behoben.
    Absturz beim Verwenden von Varia Vision mit Workouts behoben.
    Problem mit der Rückhöhenkorrektur behoben, durch das große Höhenunterschiede möglich wurden.
    Es wurde ein Problem behoben, durch das das GPS-Datenfeld nicht mit dem in der Statusleiste angezeigten GPS übereinstimmt.
    Problem behoben, durch das virtuelle Partnerfunktionen für GPX TRK-Kurse von Drittanbietern deaktiviert wurden.
    Die aktuelle Softwareversion wurde der Power-On-Seite hinzugefügt.
    Probleme mit Gerätetransfers behoben.
    Wenn Sie ein Segment fertigstellen, wird jetzt die Hintergrundbeleuchtung eingeschaltet.
    Der Höhenmesser-Seite wurde ein Mindestmaßstab hinzugefügt, damit kleine Höhenbereiche richtig reflektiert werden.
    Problem mit dem Zoomen der Höhe bei großen Strecken / Aktivitäten / Segmenten (> 100 Meilen oder km) behoben.
    Automatischer Start der Aktivität bei stehendem Gerät verbessert.
    Radarton wurde aktualisiert, um leichter zu hören.
    Kleinere Fehlerbehebungen und Stabilitätsverbesserungen.
    Bei mir wird das Update in Gamin Express nicht angezeigt, sollte aber bald kommen.
    Zitieren
  • Habs gestern installiert, eine zusätzliche GPS Installation gab es nicht mehr, ist das bei euch auch so, meine diejenigen die zuvor auch die Beta mit Galileo installiert hatten?
  • Ich denke, das ist normal. Wir Beta-User haben die notwendige GPS Software ja schon drauf.
    Die v7.00 entspricht ja so ziemlich der letzten Beta-Version.
  • Wollte nur auf Nummer sicher gehen, da ich derzeit ja quasi nur Indoor ohne GPS unterwegs bin, muss mal gucken, auf der Fenix sieht man die Versionen ja immer schön unter Einstellungen -> Info
    nicht das es da eine aktuellere Version gibt, die irgendwo hängt, hab ja solche Szenarien mit der Fenix schon erlebt :-)
  • Sauber, endlich Whatsapp - feine Sache, danke. :o
    Funktioniert, wenn auch nur Kurzantworten, aber mehr braucht man beim Radeln eh net.
    Ich bin kein Beta Tester.
    Mir wurde auf dem Gerät angezeigt das die V7 verfügbar ist. Die Installation ging in einem Rutsch durch, auch die GPS Daten waren danach gleich verfügbar.
  • Finde ich auch genial mit den Whatsapp- und sonstigen Kurznarichten.
    Werden Narichten nicht kurz in einem kleinen Fenster auf dem Hauptbildschirm dargestellt, wenn welche ankommen?
    Ich muss erst die Smart Notification-Leiste runterwischen und zu den Narichten nach links wischen, dass ich diese sehen kann.
    Doch, ploppen eigentlich von allein auf. Auf jeden Fall in der Kartenansicht, mehr habe ich nicht getestet.
  • Super, funktioniert :)
    Vielen Dank
  • Galileo offiziell noch immer Beta in 7.00?
    ... New Beta Feature: Galileo satellites. There is now support to use the Galileo network of satellites to assist in getting GPS fixes. With the correct GPS firmware, this option can be enabled by selecting GPS+Galileo in the GPS setting. Sync the device with Garmin Express to make sure that the new line of GPS firmware is provided to the device. Without this, the option will not be available.....
    https://www8.garmin.com/support/download_details.jsp?id=12335
