RWGPS Pinned Routes not Synching
Title says it all - used to be I could Pin a route in RWGPS and when I next synch'd my 1030 the route would show up in Saved Saved Courses.  Recently the courses are synching to Garmin Connect (I can see them in the App as well as the website), but do not synch over to my 1030.  I've hunted through my settings and cannot find what might have changed (I did not specifically change anything).  Additionally the courses do automatically synch to my Garmin Epix, just not my 1030.
  • If it is like Strava sync it does it only once when a route is starred (equivalent of pinned). If you need the route to be transferred again, in Strava the trick is to unstrar and then star again. The sync occurs then. So if that works the same with RWGPS, I would say in the the RWGPS web page, unpin the route and pin it again, two simple clicks. And then have your Edge sync and see what happen. In the end this functionality is really just a transfer, it is not a sync proper.
  • Good suggestion, thanks. This has been over multiple routes over a couple of weeks and none have sync’d.  I did just purge my Edge of all Courses and managed to get one to sync now so I am guess somehow I had too many routes saved?  No idea because the device had a lot of memory remaining.
  • have a look how many routes/tracks are stored in your folder Courses....  Garmin comes with a limit of 100 storable routes/tracks, its not a question of space at all.
  • Thanks - think you might have been right. Deleted all my old courses off the 1030 and now they seem to sync. Why wouldn’t there be at least a message that you reached the limit, or alternatively just replace oldest with new with a way to pin routes on the device to make sure they aren’t replaced?
  • On that particular issue, the Edge is limited to 100 routes no matter the storage.
  • You've checked your settings and couldn't find Bedava MP3 İndirme anything that might have caused this issue, and you haven't made any specific changes to your settings. Additionally, the courses are syncing to your Garmin Epix but not your 1030.
