This, I know will be the wrong forum to ask this but. I have spotted a incorrect road name. How do I go about reporting this to those cartographers at Garmin?
Indicate exactly where the issue is (and what the name should be).
Maybe, I'll fix it.
Garmin includes maps based on Openstreetmap (OSM). Anybody can edit those maps.
(You won't see the change on your unit very quickly: Garmin updates the maps about twice a year.)
@jeffus: You can change it yourself if you're familiar with Openstreetmap. Otherwise same suggestion as @dpawlyk: Describe location and wrong name and correct name. I might be able to fix it,
@dpawlyk: depending the location of the road and by using Openstreetmap it can also be one week :-)
donaldgroen
I did say "Anybody can edit those maps."
The name of the road should be Pytcheleys Hollow however it is down as Hambletts Hollow. There are (incorrectly) two roads with the same name , the dead end is correct. These can be found in Norley England. N53° 14.914' W2° 38.629'
https://www.google.co.uk/maps/@53.2485243,-2.6471863,17.29z?hl=en
The problem may not be with Opensteetmap as I have down loaded such a map and it is fine .. The error looks like it is only seen when I view the road using Garrmin connect
