Tengo problemas con datos de equilibrio de pedaleo en Favero Asioma
Desde la última actualización del Garmin 1030 me sale un pantalla para que actualice un sensor, el cual no corresponde con ningún sensor de los que tengo puestos en la bici,  y me da datos errones en el equilibrio de pedaleo  con unos parámetros de 45%-55%,,,,, nunca antes me había pasado desde hace 2 años que uso estos pedales potenciómetro,  alguien sabe como solucionarlo??
  • Since the last update of the Garmin 1030 I get a screen to update a sensor, which does not correspond to any sensor that I have on the bike
    Moved thread to Edge 1030 forum
  • share a FIT file with us, but what i suggest to do at first: #1 tighten well (40NM) both pedals, especially the left side. #2 You can reset your Assiomas with the charger cable (unplugged!), just hold the charger head to the Assioma logo on the pedal and wait for the led blinking procedure (15-20secs apprx ), do it on both pedals, it will reset the pedal's firmware and settings, and test it again (1st you need to pedal contiously with ~80rpm for 20secs apprx to get power data , after do a manual zero calibration and test the balance and everything again)
