Edge 1030 + Edge External Battery Pack stem mount
Hi
I am looking for a stem mount similar to the XBT-30 from XON (https://www.xonbikes.com/) that can be used for a Garmin Edge 1030 together with the Edge external battery pack.
Since I use an aero handlebar from ProVibe (see pic) I cannot use the standard Edge mount from Garmin.since the space between stem and the aero shape of the handlebar is to narrow.
Further more the V13 stem from Canyon does not allow any mounting underneath the stem.
Any suggestion appreciated.
BR
/Peter
  • I have a suspicion that there is no such mount available. I also have an aero bar that prohibits use of the Garmin mount, and the integrated mount that is on the front of my stem is like yours. There is simply no option for mine.
  • Same bars, same problem for me. Unfortunately I'm not fast enough to complete a everesting, before my battery runs out. I'm also using a F3 mount, so can't use a battery pack to charge on the bike as the cable won't fit through the mount. Any help would be greatly appreciated!
  • I'm also using a F3 mount, so can't use a battery pack to charge on the bike as the cable won't fit through the mount. Any help would be greatly appreciated!
    You can't use a cable with a right-angle micro-USB end, so that rather than sticking out backwards it comes out sideways? I used to use one of those on my 1000 if the battery started to run out on long rides. I've also recharged my 1000 while riding by taking it off the mount and putting it in the side pocket of my saddlebag plugged into the powerbank. It still recorded the ride details perfectly well when placed in that location, and 20 or 30 minutes of charging was sufficient for several hours more riding.
  • Hi
    Eventually I decided to go for a stem mount from REC-Mounts, Maybe not the cheapest solution but for me function has higher priority than cost.
  • Where did you purchase this from?
  • Hi, the mount was purchased from rec-mounts.com. The web site is in Japanese but Goolge translation works well and shipping cost fair. This particular model is named Garmin Charge Power Pack Mount (GCP-BOLT) but there are numerous types of mounts available and for different bikes/stems/handle bars.
