I find it is not possible to change history live color on the map, the arrow has the same color as the history color what i not like, i try a different color like white with no result
i using fw 12.2
i using fw 12.2
I have an Edge Explore, but maybe you can use the same procedure for the 1030. You only can change the History Line Color when the Map Visibility Mode is set to Auto.
Menu -> Ride Settings -> Map -> Map Visibility Mode -> set to Auto (this is the trick),
go back, then you can set History Line Color. I have it on black, but some people set it to white in order to have a better contrast with the GPS position cursor (the little blueish triangle).
Afterwards you can set the Map Visibility Mode back to your own preference.
