Hi,
If I import a GPX file, most the route is slightly off. Which makes cycling journeys for the first time a lot more confusing. As I'm hardly ever actually shown as on the road/path correctly. It's a mess of lines.
How can I correct the route [ideally in Garmin Connect before I send it to the device] - so the route is actually on the roads/paths/etc and not slightly off?
Do I have to go through the whole map manually - or can I click an option to make it all snap to the nearest real road/path?
Thanks for any help as this has been annoying me on rides for some time
x
