I have a problem loading strava routes on my edge 1030.It reports errorcode 2050.
Does anyone knows wat this code means? Or where can I find those codes?
Thanks!
Don't use Strava Routes. You don't need it anymore. Routes from Strava will be automatically added to Garmin if you mark them with a star. You must also allow Strava to send Routes/courses to Garmin in…
I recently have the error code 2050 that would not go away after I tried everything. Anyone has figured out the answer?
and yes, my routes are already starred. no luck.
Or use the device as intended? https://support.strava.com/hc/en-us/articles/115000919304--Syncing-Strava-Routes-to-your-Garmin-Device
Strava routes (if you have a strava subscription) will sync perfectly to Garmin. I’ve never had an issue once they moved to a back end sync from the buggy Connect IQ app platform…which, BTW, the Connect IQ still works, it just isn’t supported.
Are you still trying to use the unsupported Connect IQ app or are you using the new method described in the link https://support.strava.com/hc/en-us/articles/115000919304--Syncing-Strava-Routes-to-your-Garmin-Device
Uninstall the app and use the new method.
