I use the edge to record my activites and I also have a indoor trainer paired to it. Structured Workouts via ERG mode have been working fine.
However, to be able to get power readings when riding outdoors I've bought Assioma Duo powermeter pedals which are working fine as well.
But since then, when both the assioma and indoor trainer are active, trouble starts. structured workouts using ERG mode are not beeing set properly, it seems that the powermeter pedals somehow interfere. If i set it to e.g. target power 200w, it sets it, but when pedaling it's not able to maintain this power value. ist going beyond and below that but it#s not able to hold it.
The only thing to cure this behavior is to disable the Assioma under the System -> Sensors. Doing so, indoor trainer is working finde again, but then I don't get the Cycling Dynamics provided by the Assioma pedals.
Has someone figured out how to set this up so that structured workouts are now working again using powermeters in addition?
