I would like to connect iWatch to garmin without smartphone and use heartbeat sensor.
Out of the box, the Apple Watch does not broadcast heart rate in a way that Garmin devices can consume.
I just found an apple watch app that purports to support this. I don't have an apple watch, so I can't verify that it works. It appears that you still need a phone though.
What’s the name of that app?
The iPhone is already paired to the Edge for connected features. I doubt it can run a second BT connection to the same device and make it look as a HRM.
heartbeatz uses a dongle as a bridge between the watch and the Garmin https://npe-inc.com/heartbeatz
Navigr8 uses your iPhone as the bridge but requires a subscription https://www.navigr8.com
BlueHeart also uses your iPhone as the bridge but is free so probably best to try first apps.apple.com/.../id1485503543
