Sensors dropout with Fw.10
Is anyone still having sensors dropout like on fw 9.50?
With 9.5 I started to experience several sensors dropouts, that hoped that the "Improved sensor connectivity" would fix it, but still the same way on the new firmware, when you ride aparently without any pattern it loose all the sensors and 2 seconds after all reconnected again. It use to happen at least once each hour or so, some times two ...
