Auto pause stoped working after fw 10 update
No auto pause is very useful. I disable it for MTB riding but for road cycling it is useful. You may not want to use it and that is fine, but you should not make the statement you make.
Nobody should use auto pause
I cannot support this. Autopause is a very helpful function as long as you use a speedsensor.
have you set auto pause to a specific speed or to when stopped?
Setting is at 4 kmh
It's doing you a favor. Nobody should use auto pause
I doubt you have a powermeter but if you did, auto pause has screwed your power curve. And even if you don’t, why are you discarding data. It makes no sense. If you’re stopped for more than a few minutes then fine whatever.
Sorry, I can‘t understand that. I use a powermeter. If I stop, power goes zero anyway.
don't need to record stops. I already know my metrics for that. zero. no need for data to double check that.
you ride hard for 3 minutes, oh no, a stoplight, you rest for 3 minutes but autopause is enabled. refreshed, you ride hard for 2 minutes. You now have a 5 minute power number you could never achieve if you let the clock run. Now expand it out to all time periods.
Turn auto pause off. You are discarding data.
