edge 1030 touchscreen unresponsive
Edge 1030 , all 3 buttons are working but the touchscreen is not responding
    0 Former Member over 5 years ago
    I've got the same issue - any chance you managed to fix it?
  • There is a touch screen sensitivity setting for each activity profile. Select Activity Profiles from the home screen three bar menu, select a profile, and Touch Sensitivity is the last setting - you scroll down to see it. I've found that I have to set it to High or I frequently get no response when I swipe the screen.
    OTOH, if the screen isn't responding at all, then you're not going to be able to get to that setting to change it.
    0 Former Member over 5 years ago in reply to AuldNik
    Hi, sadly it's the latter! Completely unresponsive screen, attempted a 3 button reset and now I can't change/select the language - so guessing it's a bung unit
  • Is it possible that the display is locked (by accident)?
    When device is switched on, press the ON/OFF button and look at the top of the screen.
  • I have the same issue. It operates correctly but as it warms up -for the effect of sunlight or normal operation, touchscreen won't respond any longer. I even have to wait for a couple of hours till it cools down to be able to save my work session.
    I am considering purchasing a remote control. But if you find a solution, please advise.
  • When did you buy your EDGE 1030? Originally there was a problem with the screen called "halo blue" when from the edges during then month more and more pixel started to change its color to blue or so. So I could see a box around. In my case this was replaced by Garmin under warranty and got a new device. I have been experiencing sensitivity issue for a few months and it is more and more annoying. However I cannot tell if this is related to the CPU overload (slow response) or touch screen (in)sensitivity.
  • Hi Zoli. I got it 2 years ago, and yes, I got the blue halo, too. It appeared about a year later and it thickened with time. I talked to Garmin about my sensitivity issue and they sent a replacement unit as soon as I mentioned the blue halo.
    I’m not sure the sensitivity issue relates to that blue halo as mine worked fine for about a year while I had it on my screen. I’m more inclined to think the sensitivity issue comes as a result of the harsh long hours of exposure to direct sunlight during the long rides, especially with hot sun-rain-hot sun intervals.
    And as for the CPU, I feel it's a very powerful processor. And even when it sometimes got a little slow while setting up screens and stuff like that, I have no complaints about performance in every ride's workload.
    I hope that helps!
    - RGB
  • Have you tried to adjust the sensitivity to a higher level? As  indicates, you can adjust it in each profile's settings
