1030 Bluetooth implementation really is garbage
Every other BT device I connect my phone to - headphones, keyboard, car, Edge 1000 - connects instantly and stays connected without problem. With the 1030, when I power it on it usually takes up to ten minutes to establish a connection to the phone - after I start an activity, the two don't usually connect until I've ridden somewhere between two and five kilometres - and I have never managed to get through a ride without seeing multiple instances of "phone disconnected" and then "phone connected" appearing on the 1030 display top line. It make no difference if I start GCM and leave it sitting in the foreground, there is still an extended delay before the connection gets established.
Lest anyone thinks this is indicative of a faulty unit, this is the fourth 1030 I've had, and they all have had the same BT connection problems. Garmin replaced the previous three 1030 units because they all started suffering from the screen delamination / blue halo problem. The problem has also persisted across both the phones I have had since first acquiring a 1030, and across three different versions of Android. Phone is presently a Pixel 4 running Android 10 and GCM 4.31, and 1030 has 9.50 FW, but I've had the problems all the way back to an earlier Pixel 2 phone running Android 8.1 and FW 3.something on the 1030.
  • I was able to get Android BT and 1030 connected.  I had to remove Garmin Connect and install an earlier version.
    0 Former Member over 4 years ago in reply to BourbonBill
    It seems that if you run into problems with BlueTooth connectivity, the only solution is to eradicate all references to each other on both devices, everywhere, including in the Garmin Connect app (a sad consequence of doing that, if you've got only one Garmin device, is that you also have to recreate your account in Garmin connect, which will re-download all your account data to your phone). So you need to remove your phone from the 1030, and then remove the 1030 from BlueTooth settings and from the Garmin Connect app on your phone. Forget any one of these steps, and while you might be able to re-pair the devices to each other, it won't fix the underlying problems, whether they're an inability to connect when you power up your Garmin or an inability upload ride data when you've finished a ride.
