Hi All, does anybody here make use of the 1030 VO2 Max calculations? I ride and run; my run VO2 Max is calculated by my watch; and my bike VO2 Max is calculated by my 1030. Obviously VO2 Max changes reasonably slowly overtime and day to day changes are small. Changes over a week or two are definitely possible but not really day to day. I use WKO/TrainingPeaks to actually monitor VO2 and this week compared it with laboratory data and TrainingPeaks was spot on.
What happens with my 1030 however is quite strange. My VO2Max number goes up and down significantly based on the last ride activity I log. I might get 53 on a Monday when I do VO2Max intervals; but it might be as low as 50 on a day when I do a short muscle endurance ride; or even 49 if I do an easy recovery ride - all within the same week.
While the numbers are in the ballpark with the laboratory result; it appears the 1030 places much more emphasis on the last completed ride, rather than considering a weeks worth of rides etc. Clearly a recovery ride isn't going to get anything close to VO2 Max and therefore shouldn't be used to generate a new VO2Max score.
My running VO2 Max doesn't show anything like the same level of variation. Slow recovery runs don't reduce it, hard intervals don't suddenly affect it - the graph shows a much more steady progression.
Is anybody else experiencing the same thing - do people use VO2Max?
TIA
