OK, I confess I don’t understand ant+........
I want to pair 2 Giant ebikes, both with ridecontrol1 ant+, to one Edge 1030, under seperate profiles.
My primary bike is all paired up, works well.
I set a new profile for the next bike and tried to add its sensors using the ebike sensor option and got ”connecting” on the display until my patience ran out. I could pair that bike to an Edge 310 and was a bit surprised the sensor id numbers were the same for the 2 bikes. Thought maybe the computer thinks its the same sensor,so doesn’t pair it again. Given that, I thought I might be able to see the data from the secondary bike if I use the tried and tested profile for the first bike. Nope.
So, should I be able to pair both ebikes to the same 1030?
