I had the 48 states of the USA in a single map on a microSD card, and had inserted the card into my older Edge 1030.
I decided to update the map, but when I tried to include all 48 states, I received a message from the OpenFiets web site that the selected map was too large. So I made two maps of the eastern and western halves of the country (with some overlap). The site generated my two map files, I downloaded and unzipped them, and copied one to the micro SD card, renamed it to USEast_gmapsupp.img, then copied the other and renamed it to USWest_gmapsupp.img.
When I inserted the micro SD card into the Edge 1030 and turned the device on, I could see the following maps:
Basemap, Garmin Cycle Map Amer North 2019.20, Garmin DEM Map 2019.10, Garmin Geocode Map 2019.10, Garmin Cycle Map Amer Central 2019.20, and Openfietsmap Lite
I had expected to see two Openfiets maps, with the names I had assigned to them.
If I disable the Garmin Cycle Map, I get a different looking map when I go into Navigation/ Browse Map. This makes me think the Edge is using the USWest map, since my street wouldn't be in the USEast map at all.
Can someone tell me if I did something wrong?
