New Edge 1030 Public Beta 8.06 Now Available
A new Beta software for the Edge 1030 has been released. Full change log, instructions, and software for installing the beta can be found here.
  • For any issues that you encounter please fill out the form included in the download and attach it to an email to [email protected]. Please note that you may not get a response to the email unless we need more information on the issue you report.
  • Although this software is believed to be reliable, it has not yet been released for production and should be used at your own risk.
Changes made from version 8.00 to 8.06:
  • Added support for Connect IQ 3.1.
  • Added support to control Garmin inReach remotely.
  • Made improvements to indoor cycling user experience.
    - Improved smart trainer discovery and initial setup experience when using an Indoor activity profile.
    - Improved the Follow Course experience by enabling UI (map, ClimbPro, Elevation, etc) and data recording from the simulated course.
    - Made improvements to smart trainer sensor calibration.
  • Made improvements to Workout user experience.
    - Added FTP line to workout comparison displays.
    - Allow graphical workout data fields to be configured on regular data screens.
    - Improved the display for open steps on the workout comparison graph.
  • Made improvements to the ClimbPro user experience.
    - Made ClimbPro available for navigation to a location and for round-trip courses.
    - Added a setting in the ClimbPro data screen setup to specify which climbs should be detected (All, Medium/Large, Large Only).
    - Removed the ClimbPro page from the timer loop if there are no climbs left in the ride.
  • Made improvements to the Segment user experience.
    - Fixed an issue where segments with slashes in the name would not be processed and would create subfolders on the file system.
    - Fixed an issue where the segment leader could get reset during a sync.
    - Added setting in the Segments menu to set a Default Leader Priority, which allows the user to set a default leader to apply to all segments.
  • Fixed an issue where the GPS track locked to the road inaccuarately.
  • Improved Firstbeat heat acclimation by utilizing weather forecasts.
  • Fixed an issue where Battery Save Mode could stop working mid-ride.
  • Show the jump prompt for each jump in cases where there are multiple jumps in a row.
  • Fixed issues with the heart rate graph data field.
  • Fixed an issue that caused Auto Detect Max HR to always be enabled.
  • Improved the y-scaling on the elevation profile.
  • Added directional arrows for round trip courses.
  • Fixed cosmetic issues with Extended Display mode.
  • Added additional info to the nutrition/hydration settings page
  • Turned backlight on when the user laps or there is an autolap during an activity
  • Automatically sized the text in the elevation data field.
  • Improved overall device stability by fixing crashes and freezes.
  • Hi Nik. Thanks for trying this. That's very strange all the apps I've tried have the same delays.
    How long was the course you downloaded? & was the source file a GPX or FIT.?
    Also out of interest what version of GCM is installed on your phone?
    0 Former Member in reply to hotdogpartysausage
    The course I downloaded was ~80km and in GPX format, created on the phone using Locus. GCM is 4.23.1, and phone is a Pixel 2 running Android 10.
  • Thanks for the information. I'm using the same GCM version though on an older phone with android 7.0. A GPX file of the same length created in RideWithGPS is taking 3 minutes to download to my Edge.
    There is certainly something quite bizarre happening with bluetooth comms on my Edge with these beta builds. My RideWithGPS IQ app stalls at the initial 'Loading' splash screen when launched and doesn't progress any further.
    However if I turn Bluetooth off on my phone then launch the RideWithGPS app; I get a 'Waiting for phone connection'  splash screen message as is normal. Then when I turn Bluetooth back on & the Edge establishes a connection the app immediately displays the menus, which allows me to select & download routes. ie. is working normally albeit downloading the routes much slower than it used to.
    If I then exit the RideWithGPS app & relaunch it; the app stalls at the initial 'Loading' splash screen again and doesn't progress any further. Even if I turn Bluetooth on my phone off then back on again whilst the 'Loading' screen is displayed it still won't progress.
    I've tried removing & reinstalling the apps, unpairing, deleting & adding the Edge from GCM & Phone Bluetooth. I've even tried pairing the Edge with my tablet instead of the phone. With the same delays & app responses as previously seen.
    Unless anyone has any other suggestions/solutions I might have to bite the bullet, backup my settings & master reset the Edge to see if that solves it
  • didn't happen though ...
