Training status with more than one device V7.85
Hi, I was hoping with v 7.85 that we might be getting consistent training status's across multiple devices.  At least on the beta that isn't happening - is this happening with everybody?
My 7-day training loads are now showing correctly on both my Marq and 1030.  Both show a training load of 557.  Here are the activities:
What I'm struggling with is the 1030 shows my training as Productive, the Marq shows my training as Unproductive.  Which is right??  Any ideas?
TIA
  • Maybe slightly related, my Garmin 935 and Edge 1030 were in sync and training load was same on both before update to 7.85.  During the update the Edge 1030 flashed up re-calculating training load on startup and now is reading way higher than the 935, a few hundred points higher.  So not sure what happened there.  Hopefully they will come back into line again after a few weeks.  But what was that re-calculation for and if its needed on edge 1030 then it would be needed on other devices also??
  • Before update to 7.85 :
    After update to 7.85 (big increase of training load after the 1030 re-calc ??) :
  • My problem is basically the same, my Marq is heading in one direction, and the Edge is heading in a different direction.  What we really want is a single combined Training Status.
    • Same problem for me. Fenix 5x plus, edge 1030, 7.85.
  • 1099 on Fenix and 1399 on Edge (7.85) after today's ride. Going back to 7.50 now. Disappointed
  • Downgraded to 7.50 and both fenix and edge shows same training load. No more beta 7.85 for me.
    0 Former Member over 5 years ago
    Must be something wrong with training status too, did a workout today, fenix 5 says Training effect 3.4 on Aerobic, 2.8 on anaerobic, but my 1030 says 5.0 and 3.2. Same with my Forerunner 945. Don't know what to believe anymore. Maybe revert to 7.50 again, but i loose all settings.
  • Did you try to re synch your watch after adding an activity to the edge ?
    For me with a 945 and Edge 1030 it wasn't working with 7.5 but it works now with 7.85
    before going for a ride I synch the edge so it has the same training status as the 945 then when I finished my ride and the edge is synched, I synch back the watch and everything is fine
  • Same process, everything fine.
  • With FR935 (v14.10) and Edge 1030 (v7.40)  the training status stayed in sync through true up.
    Now from Edge 1030 Beta (7.85) the edge has received new FirstBeat metrics (e.g. Load Focus) and performed a re-calculation of training load and status.  Since then and for a number of weeks it is reading differently to my FR935.
    Will this ever come back in line?  Will there be an equivalent update for the FR935?  Or Will this now only work properly with the FR945 which also has the newer FirstBeat metrics?
