Hi all,
I am having trouble getting a right-side only Stages power meter to connect properly with my 1030. For starters i've ensured that the firmware is up to date for units. Here's what I've done and what's still happening:
I was having trouble getting the 1030 to see the Stages properly so I followed some instructions in one of the other forum threads and created an entry in the 1030 for the Stages via BLE and ANT+ (not running both at the same time). The ANT+ will not calibrate the Stages... it simply spins and spins trying. Switching it off and the BLE entry on it finds the Stages OK, gives the proper info about the unit, but when I try to calibrate it will only give me "0" reading. And, yes, I've got the crank oriented properly towards the ground. I am at my wit's end. Any ideas why it might not be calibrating properly?
Thanks, George
