Gradient issues.
Shockingly inaccurate. On flats it’s flashing up between -15% and plus 20%. Never had issue on my 1000.
  • Does it happen every time? I had gradient issues on a ride in the Lakes, never got a reading steeper than 5% even on Hardknott. However, it reverted to normal service next time I used it. It's an issue I've occasionally experienced on other Garmin units, and I assume it's caused by unusual barometric conditions.
  • Check that nothing is covering or blocking the port used for the barometric sensor.
    It is the two small wholes on the back of the unit. The 4 small holes are for the speaker.
  • I had a similar issue (maybe not as bad as you have decribed).  I had noticed that my speed sensor (Bontrager) had been temporomental, I removed it and the gradient returned to normal operation.  Probably not the same issue, but I throught it was worht posting.
