Where is the physical location of the GPS antenna on the 1030? I am wondering if my aftermarket case is interfering with the GPS signal at times. My friend and I road the exact same Strava segment and his 1030 recorded all of the segment correctly and my 1030 didn’t. The only difference is I have this case on. I opened a ticket with Strava and they were able to fix the file so the segment showed up. Strava said there were some gaps in the GPS data capture during the segment possibly caused by the tree cover. Again I was following my friend and his 1030 was able to record the segment correctly.
