Extended turn notice screen duration
In the past week my Edge 1000 has started leaving the turn notification screen on FAR longer than it used to.  It comes on 300' before the turn as I have it set to do.  OK so far.   It used to turn back to the original screen about 100 feet after the turn.  But now that zoomed map screen is staying on for just under a a minute (way more than 300').  It doesn't even reset if there is another quick turn withing that time window.  I don't see any setting either on the Garmin unit or on Ride With GPS which I use to generate routes.  I know I can tap the screen to get it to return to the default screen but that's annoying to do when riding on route with a lot of turns.  Any clue?
