The Shiman0 2.0 protocol supports the Di2 system sending across the size of the front rings and rear cassette. This is configured using the e-tube app either on a phone or on a Windows machine.
You can configure the 1030 to either accept the values sent by the Di2 system or ignore them and manually set the sizes using the Edge. You need to be in communication with the Di2 system to see the UI option.
Not wanting to threadjack the other Di2 discussion, but what are the specific chainring/cog options available to manually configure a chainset in the Edge Di2 setup? Is this documented anywhere?
The options in the E-Tube app are terrible (because Shimano has no clue how people actually setup their bikes), for example, a 50/34 crank has to be configured as a 53/39 in E-Tube in order to trick the rear derailleur to be able to shift into the small chainring/cog, to uncomplicate removing/replacing a rear wheel.
Can this be overridden in the Edge 1030 setup to properly record “nonstandard”/non-Shimano gearing into the FIT file? Are the Edge options restricted to only cranks and cassettes that Shimano sells?
