Issue with Shimano Di2
Any ideas?
I have and Edge 1030 running firmware V7.00 (tried 7.2 but that caused the touchscreen to stop responding while connected to an external USB power source so reverted)
I've been running shimano's Di2 with both a front and rear derailleur and displaying my gearing on the Edge. This worked great both before update and reverting the the firmware to 7.00
I took off the front derailleur when I installed a Bafang BBSHD and now I'm having an issue where the Garmin isn't showing the correct rear derailleur gear. Eventually it will update but not immediately like before or consistently.
I've tried deleting the D-fly and reinstalling it but the problem hasn't gone away. I also thought it might be having an RF interference so moved the D-fly to withing an inch of the Garmin no change. Also both the speed and separate cadence sensor both responding and displaying correctly.
Any ideas would be appreciated.
Angelica
  • Seems like the Shimano was not reporting the front derailleur information due to the missing cable and the Edge was simply showing the result of this.
    Without see the actual programming code for both the Garmin and the Di2 here is my guess.
    The d-fly is sending out a beacon with the gear when you shift. It's either comprised of two different data sets one for front and one for rear or it's a combine data set. The Garmin is expecting both before it'll update the data field regardless if that field is only displaying the rear gear. The Di2 though isn't send the data set for the front derailleur. So the Garmin doesn't update the display because it's waiting for the front gear data set. It eventually updates because something else is triggering the display update. Possibly a timeout or one of the other sensors trigger a full display update at which point it updates the rear gear displayed.
    When the front derailleur is connected even when not in use the Di2 is sending that full data set via the D-fly. I know the Di2 sees the front derailleur because when it's plugged in its showing front as in lower gear whereas when it's not plugged it it doesn't show anything for the front at all.
    Annoying is what it is. I don't know if people are having this same problem with the XT/XTR Di2 which you would more commonly see run as a 1X setup but it is an issue with the Ultegra which is what I have.
    Right now I'm running it as a 1X because I installed a Bafang BBHD so I'm unlikely to run dual chainrings at least not until I get motivated to machine a front derailleur adapter to compensate for the chainline of the Bafang.
    0 Former Member over 5 years ago in reply to Former Member
    Hello,
    My English is very bad.
    I can't understand if it solved the problem, I stopped updating the edge 1030 firmware in v. 5.0.
    If I update the change of the xtr di2 it takes minutes to update on the edge 1030 ....
    there's a solution?
